Hand Throttle?
Old Apr 23, 2007 | 04:17 PM
POTO's Avatar
Default Hand Throttle?
Has anyone here attempted to add a hand throttle to their JK yet. I had one on the TJ and it came in hand many a time on the rocks, and while doing recovery with the winch to keep the RPMs up, also when I let the TJ sit to long and it needed a jump and throttle to keep it idling.
I've been thinking of making a hand throttle my first mod, due to it's relatively inexpensiveness. Anyone put any thoughts to this, since the throttle at the intake is controlled by electric and not a regular throttle cable(unless I'm looking in the spot) . Is there a throttle cable anywhere?
Old Apr 23, 2007 | 04:22 PM
Robar's Avatar
The JK's throtle is electronic. You may have a more difficult time doing this than with the TJ. You would need some type of electronic controller to regulate the throtle.
Old Apr 23, 2007 | 06:22 PM
POTO's Avatar
that's what I was thinking if it was electronic. An open circuit would be no throttle, and a variable resistance would produce a climb in voltage, to open up the throttle. It would be easy to piggy back the throttle. The hard part would be controlling the voltage. Anybody got an FSM with the wiring?
Old Apr 23, 2007 | 08:11 PM
BJeepJK's Avatar
Originally Posted by BeerMonkey
technically it would be easy if anyoen could figure out hwo ithe system works it would be aws easy as un pliggin hthe peadl and piggybacking a hand thrttle in
LOL ... WHAT???
Old Apr 23, 2007 | 08:21 PM
muddpuppy01's Avatar
technically it would be easy if anyone could figure out how the system works it would be as easy as unpluggin the pedal and piggybacking a hand throttle in
fixed it for you
Old Apr 23, 2007 | 09:04 PM
2K1TJ's Avatar
Originally Posted by BJeepJK
LOL ... WHAT???
He he, look at his screen name. Looks like the Monkey got in the Beer
Old Sep 5, 2007 | 07:56 PM
Jonnyworld's Avatar
bump.......
Old Sep 5, 2007 | 08:18 PM
bOLsAK=3's Avatar
Whoh!!! BeerMonkey needs to change his name to DT'sMonkey!!
Old Sep 6, 2007 | 04:09 AM
John L's Avatar
I'd probably start with unplugging the pedal and seeing what it's actually doing. Since we are all on the CAN system, it may vary a PWM signal to the throttle controller. Or it may be set up like a stepper motor system. Good idea from Beer Monkey, maybe easy just to buy the pedal interface component, adapt it to a handheld device and plug it in.
Old Sep 6, 2007 | 05:04 AM
ROKLIMO's Avatar
I think I saw a thread somewhere where someone had installed one, but can't seem to find it now.
These guys are supposed to have one out soon...
offroadengineering.com
