Hand throttle on a JK??
Hey guys. I have an 07 Rubicon 6 speed and I've been recently introduced to some serious Rock crawling and hill climbing.
I'm having a hell of a time driving a stick so I was wondering with the drive by wire system if its possible to do a hand throttle or a high idle switch?
I've had some luck using an aev procal with the winch high idle setting. But its a little annoying plugging and unplugging it in. Plus the ebrake needs one click for it to work.
So any suggestions or ideas would be great.
Thanks guys
Thanks guys
The only one I've ever seen is the one by off road engineering. Most people like them that I have read but I have no experience with them.
http://www.offroadengineering.com/pr...road-jeep.html
2007 Rubicon /2 door/6 speed
I saw a post that said they where $285 but that was in 2010 so the price may have changed probably have to contact them. Here is a good article on it.
http://www.fourwheeler.com/project-v...er-jk-rubicon/
I have a 2007 6 speed Sahara and have done some decent rock crawling, the Rubicon, for one. I have found that the crawl tune on the superchips tuner really helps with throttle control. You may also want to re-gear to 4.88 or 5.13 to help slow you down. The biggest improvement was installing the 4:1 transfer case, you already have that.
