Harsh ride, springs or shocks?
Old Nov 27, 2013 | 11:18 AM
sir_burns's Avatar
Default Harsh ride, springs or shocks?
I am trying to pinpoint on my lift what is causing the stiff ride. Currently i'm running AEV 3.5" springs, Rubicon Express Monotube shocks, AEV front control arm brackets, JKS rear swaybar links, longer front swaybar links, JKS front adjustable track bar, rear trackbar bracket.. Axles are centered and I have Falken 305/65R18 mounted on stock Sahara wheels with spidertrax wheel spacers.. It seriously feels like I have an inch of upward travel.. hitting ruts, potholes, speed bump etc. feel really hard. If I hit a bump hard I feel my tires lose contact with the ground. The Rubicon express monotubes are made by bilstein and are essentially the same as the 5100s. I have stock bumpers, no armour etc. just the lift.. I run around 24-27 psi in my tires as they are e-rated..
Old Nov 27, 2013 | 11:22 AM
planman's Avatar
Forum Tech Advisor
In your case, it is the combination of AEV springs with out a heavy load (they are designed for AEV bumpers and a front winch), and the load range E tires.
Bilsteins are a little on the stiffer side, but the real issue is the springs designed for very heavy loads. AEV bumpers, with rear containers and a front winch add about 400+ lbs in weight.
Old Nov 27, 2013 | 01:07 PM
sir_burns's Avatar
That's what i was thinking.. Read a lot of good reviews on these springs. I new to a certain degree that they were stiffer without load, but they are really stiff springs..lol.. They should advertise these things to be only installed with 400+ pounds of extra wieght loaded on the JK
Old Nov 27, 2013 | 01:22 PM
kjeeper10's Avatar
Vet Army
Honestly, I've installed
- RC 2.5's Friends
- TF 2.5's mine
- RK 2.5's mine
- AEV 2.5's friends
I swear the AEV coils were the easiest to compress and install. Maybe it was the wheaties that morning,, who knows
I am going to guess shocks in your case. The 5100's are pretty firm shocks. If yours are similar to the 5100 and charged the same ..?
Fwiw, I've driven 2 AEV equipped jeeps. Both 2 doors. One with bumpers/skids, the other stock. The heavier jeep did ride better.
Old Nov 27, 2013 | 01:24 PM
kjeeper10's Avatar
Vet Army
Should of noted ...
I have a 2 door with E rated 35's. Shocks made a huge difference. Even with E tires. I'm running Rancho 7000's with less nitrogen charge than the 5100's.
Old Nov 27, 2013 | 08:01 PM
Freewill's Avatar
It will probably ride best with the Bilstein shocks from AEV that are tuned to match the AEV springs.
Old Nov 27, 2013 | 08:38 PM
kjeeper10's Avatar
Vet Army
Not true. There's a fellow recently who bought the AEV 2.5 and Rancho 9000 shocks. Loves the ride.
Old Nov 28, 2013 | 07:25 AM
big dr's Avatar
you could always try OME,, they are known for a more plush ride.
Old Nov 28, 2013 | 09:43 PM
Freewill's Avatar
Not saying that fellow's ride isn't OK, just that the AEV tuned shock/spring combo is one that will give predictably good results, possibly better than his. (This is true of any combo that has been correctlly engineered to work right together.)
Also, one owner's great ride might be a total dud for another owner. That's the great part of modding a Jeep to get what you want.
Old Nov 29, 2013 | 10:39 AM
TJJK's Avatar
Especially when using a coil spring that has a compression rate better suited for the weight being carried.
