Hawse fairlead OK with standard cable?
Old Oct 12, 2007 | 01:25 PM
ski313's Avatar
Default Hawse fairlead OK with standard cable?
Sorry for this stupid question but I prefer the looks of a hawse fairlead to the standard roller fairlead. Will I do any damage to my standard winch cable switching the two? I do plan on switching to synthetic winch line in the future but not right away. Thanks!
Old Oct 12, 2007 | 01:37 PM
IGOFSHN's Avatar
A lot of winches come standard with a hawse fairlead. You won't cause any damage.
Old Oct 12, 2007 | 01:44 PM
wayoflife's Avatar
JK-Forum Founder
What IGOFSHN said but if you use your winch with it's steel cable, you will need to install a new fairlead when you switch over to synth rope. The abrasions caused by the steel cable can damage/cut up synth. Also, you should make a point to get an aluminum or plastic hawse when you go synth.
Old Oct 12, 2007 | 01:46 PM
1BADJK's Avatar
So your saying I can run a Non-Roller Fairlead with a steel cable???? I was told the oposite by Warn...
Old Oct 12, 2007 | 01:50 PM
ski313's Avatar
Thank you guys, this is the most helpful website EVER! I think I am really just glad you gave me the answer I wanted. WOL, thanks I would have never thought of changing fairlead again after synth. switch. Great info.
Old Oct 12, 2007 | 03:08 PM
Duke's Avatar
Approved configurations.........
Steel cable with roller or steel hawse fairlead
Synthetic cable with aluminum or plastic hawse fairlead
