HD tie rod question
Old Aug 4, 2009 | 07:29 AM
shredX's Avatar
Default HD tie rod question
Are there any clearance issue with a HD tier od, like the one from JKS, and a Solid front diff cover?
The JKS tie rod is straight and the stock unit appears to have a bend on the driver's side.
Mine is not tacco'd yet, but it may have a slight bow to it. I need to take a closer look.
Thanks!
Old Aug 4, 2009 | 08:53 AM
jkJason's Avatar
If your worried about clearance offroad only makes a tie rod kit that uses a straight tie rod with these relocating tabs that moves the tie rod up and slightly out. Not as high as a high steer/steering knuckle flip but theres not enough room for that. More clearance from the diff and from rocks. ps not a salesman haha I've jes been looking at these a lot an thats what I would do.
Old Aug 4, 2009 | 10:39 AM
shredX's Avatar
Actually, I was thinking RK, not JKS. Thanks. Ill have to check out offroad only.
Thanks!
Old Aug 4, 2009 | 11:09 AM
shredX's Avatar
Wow, those are pricey. May have to weigh the cost of just replacing with stock...
Old Aug 4, 2009 | 11:16 AM
CTNEDGE's Avatar
If you can swing it it's worth replacing with a Rock Krawler. Stock replacement will be revisited in the future guaranteed. Get the Rock Krawler and your worries are over...
