Headlight upgrade
Old Jan 4, 2014 | 06:07 PM
iiM RuSHiN's Avatar
Default Headlight upgrade
I'm looking to upgrade my headlights because I removed the factory fogs when I put on my bumper. The headlights just aren't working well on the flats in Utah at night and I need some advice. I know the truck lite route and have considered it, but they are very expensive and if I can find something else I would be happy. On an old rig I changed out just the bulbs for a white light bulb and that helped a little bit but not enough, opinions? Thanks for the help.
Old Jan 4, 2014 | 06:13 PM
daninbend's Avatar
Probably not what you want to hear, but I just did the same research and went with the TruckLites. Get the harness too so they don't flicker. Huge improvement over stock lights.
Old Jan 4, 2014 | 06:52 PM
BobV's Avatar
If you aren't set on LED lights I have read a lot of good things on here about the IPF headlight kit. Comes with new housings and bulbs. Supposed to be plug and play and much brighter white light. This is what I am leaning towards because it would kill me to spend $400 on headlights
Old Jan 4, 2014 | 07:02 PM
holmes4x4's Avatar
What about the kc hi lights kit and get the H4 bulb up grades with like a top line silverstar bulb an option and will only cost you about $175
Old Jan 4, 2014 | 07:34 PM
chairdr's Avatar
Suck up the cost. Trucklite 7 and the harnesses are the only way to go.they are sick bright
Old Jan 4, 2014 | 07:39 PM
robsjeep9's Avatar
JK-Forum Ambassador
Have they fixed their harness problem yet? I had them for about 6 months then sold them to a friend more handy then myself lol I was tired of having the one light go out all the time because of a poor connection.
Old Jan 4, 2014 | 08:01 PM
chairdr's Avatar
Y. Harness available from quadratec and rebel offroad
Old Jan 10, 2014 | 05:28 PM
Quentin_T's Avatar
I have had the IPF H4 conversion for a few years now and I love it. The lights are a little blue for my taste so I ended up switching to silverstars. The harness adapters sucked, and I had to cut and solder so they would stay on.
Old Jan 10, 2014 | 07:09 PM
Falcon8JK's Avatar
I just put a set of TruckLites in with the PWM harnesses. They are awesome! It killed me to drop that kind of coin on headlights, but they were worth it.
Old Jan 10, 2014 | 07:27 PM
CerOf's Avatar
If you don't care/need DOT compliant, go with Rebels. A test I read put them on par with trucklites or better! They use stock reflectors and the beam pattern is quite impressive. Half the cost too!
Sent from some string and a few tin cans.
