Headlight Washer Set Up?
Old Jan 3, 2014 | 07:45 PM
Jeepstin12's Avatar
Default Headlight Washer Set Up?
K. This time, I did a search on the forum before posting and found nothing. Has anyone installed a headlight washer system? If so, what brand, components did you use? If no one, I am going to piece one together. I already looked at the parts I need. I am also thinking of running it on its own switch and pump as opposed to tapping it into the existing pump or switch. This way, I can clean the lights independently from the windshield.
Old Jan 3, 2014 | 08:13 PM
karls's Avatar
Are you going to install a small wiper arm as well or just a little pump to spritz the lenses? It seems like you'd be setting yourself up with quite the project with a wiper. Any plans to heat the fluid going to the headlights? My guess is this is all arising from snow/ slush/ ice issues??
Sent from my GT-P5113 using Tapatalk
Old Jan 3, 2014 | 08:50 PM
Skotler75's Avatar
Ditch the wiper idea and throw on some rain-x. Perfect every time
Old Jan 3, 2014 | 11:17 PM
KY JK's Avatar
I was thinking about this driving through an ice storm with my Truck lites not giving off enough heat to melt ice off. My Jeep came with a hard top that I no longer have and I was thinking of rerouting the rear sprayer to the front for headlights? Need to look into sprayer options with a wide angle in a short distance?
Old Jan 4, 2014 | 05:59 AM
Jeepstin12's Avatar
Not running wipers. Rain X doesn't work when you are deep in the Colorado Rockies, running highway speeds for a few hours, and I like the thought of moving the rest to the front, that would be easy, but I still use both tops and use the rear a lot. And, I am looking at different nozzles. They all come in different heights and angles. Not sure if I will heat it or not. I may......... I just need to prod around, check clearances, attachment points, etc. Surprisingly, it's not expensive at all. About $60 in pats and shipping and mounting/running everything.
Old Jan 4, 2014 | 06:39 AM
Jersey_Devil's Avatar
Have u tried to go to a junk yard and pull the wiper sys outta an old volvo and just adapt it to the JK
Old Jan 4, 2014 | 07:22 AM
JeepingNet's Avatar
Our headlights are so round, concave and recessed i'm not sure you'd get much great results.
I'd be more tempted to try to run some kind of heat to the area.
Old Jan 4, 2014 | 07:24 PM
Jeepstin12's Avatar
Originally Posted by JeepingNet
Our headlights are so round, concave and recessed i'm not sure you'd get much great results. I'd be more tempted to try to run some kind of heat to the area.
heat doesn't remove road grime.
As for the junk yard, this us going to sound a bit "snobby", but I'm one of those guys, that when I set out to do something, I do it right the first time. I have the "I'm too poor to buy cheap" mentality. Besides, the parts total, is only about $60 max. If we were talking hundreds, I would reconsider.
Old Jan 4, 2014 | 07:51 PM
ahfunaki's Avatar
I think the JK is the perfect vehicle to do this to.
Since the headlights are recessed, you can mount the sprayer right in front of the headlight. It might just take a little but of trial and error to get the spray pattern right.
Also since the grille is so easily removed and made of plastic modifying it should be pretty easy.
I'm interested to see how this turns out.
Old Jan 4, 2014 | 07:58 PM
courtsm3's Avatar
Look at the AEV dual sprayer kit. Might get you started.
