Heat sink tranny coolers
Old May 14, 2008 | 08:45 AM
Midblues's Avatar
Default Heat sink tranny coolers
Has anyone tried the heat sink trany coolers they will not block the radiator at all and are very tuff and easy to install, also cheap, you mont them on the bottom in front of radiator,take aook at derale .com I think Im going to try one.
Old May 16, 2008 | 11:33 AM
robertangelodibernardo's Avatar
I mounted a heat sink cooler from jegs a few weeks ago, after reading up on all the JK AT overheating issues. As a former open track and drag racer, I learned that blocking the radiator and AC condesor with a standard style tranny cooler does impact the water temp and your AC condensor temp., particulary at slow speeds. The issue with the JK stock cooler is mostly that it get almost no direct airflow due to its low placment on the grill. jeep really cheaped this one out on us.
I mounted my heat sink cooler to the metal brace/frame that sits below the radiator, after I removed the grill. The idea being that it adds a quart of extra capacity, does not need a lot of air flow to be effective, and looks kinda cool sitting in front of the radiator. It is alos not impaxcted by mud/sand debris.
If you go this wasy, be suere to sue the type that has the inlet/outlet on the smae side- reduce the installation PITA factor.
I'll post a photo if you are interested.
Old May 16, 2008 | 11:37 AM
Blue's Avatar
robertangelodibernardo,
Did you use the 21" Jegs cooler #555-60352?
Old May 16, 2008 | 11:38 AM
j&k'sjk's Avatar
i agree. good advice.
Old May 16, 2008 | 11:42 AM
VBS4's Avatar
Oh come on....lol Like no one would be interested in seeing that
Bring on the pic.s
Old May 16, 2008 | 12:04 PM
bbkoz's Avatar
I'd appreciate it if you would post a picture. I'm interested in installing a heat sink cooler.
Old May 16, 2008 | 07:31 PM
seer1's Avatar
Definitely would love to see to see the picts.
Old May 16, 2008 | 07:55 PM
serveapurpose's Avatar
Sponsoring Vendor
Off Road Evolution Rep
ok it is pic time please of course
Old May 16, 2008 | 08:37 PM
JKFirefighter's Avatar
Yea, post some pics dammit.
Old May 16, 2008 | 10:13 PM
deconstructionist's Avatar
awaiting d' pics
