Help!!!!
Old Feb 5, 2010 | 10:12 AM
mdmmd's Avatar
Default Help!!!!
My hub/bearing is seized onto the steering knuckle. How do I get it off without spending a few hundred bucks on a an air driven slide hammer?
Old Feb 5, 2010 | 10:18 AM
captjay's Avatar
i have not run into that issue, but maybe a propane torch and apply heat with some taps of a mallet or hammer
Old Feb 5, 2010 | 10:21 AM
captjay's Avatar
Originally Posted by planman
I wouldn't want to overheat the bearings.
true, sorry i forget not everyone replaces bearings. if i have to remove any bearing anywhere, then i replace with new.
good call
Old Feb 5, 2010 | 10:40 AM
mdmmd's Avatar
I found a slide hammer at my local NAPA for $80. looks like the job just got more expensive. Does everyone agree that i should replace the hub since im there??
Old Feb 5, 2010 | 11:23 AM
jackson2010jk's Avatar
Around these parts, you rent the slide hammer, and when you bring it back, they refund you all your money.
Not sure how it is around you, but worth a shot
Old Feb 5, 2010 | 11:25 AM
john smack's Avatar
gotta love canadian tires free rent a tool
