Help
Old Aug 10, 2013 | 10:19 PM
bchapman's Avatar
Default Help
can 37 x 12.50 tires be mounted onto the stock rims from a 2011 rubicon?
Old Aug 10, 2013 | 10:50 PM
nthinuf's Avatar
Yes.
Some shops may not mount them for you, though, since the stock rims are narrower than the tire mfg's recommended minimum width.
Since you will meed wheel spacers also, you might just consider buying wider rims with the appropriate backspace instead.
