Help!!
Old Feb 4, 2014 | 04:21 PM
ronixwrangler's Avatar
Default Help!!
It's installed my RK 2.5, when I drive down the road and get over 10 mph my antilock brakes kick in, what do I do??
Old Feb 4, 2014 | 04:24 PM
DunnyBunny's Avatar
JK-Forum Ambassador
Did you adjust the draglink to recenter steering wheel?
nthinuf's Avatar
Straighten the steering wheel ?
Old Feb 4, 2014 | 04:38 PM
Thanks so much guys, that was the problem.
Old Feb 5, 2014 | 05:35 AM
last night before i adjusted the wheel, when the antilocks were kicking in, i could smell like a burnt smell. i figured that was from the brakes kicking in so often, i fixed the stearing last night and the antilocks do not kick in anymore, but when i got to work this a.m about a 5 mile drive from my house i still smelt that burnt smell, any ideas what that could be?? maybe i got some wd40 on my exhasut, idk... any experiences with a weird smell after lift??
Old Feb 5, 2014 | 05:39 AM
Cfitz22's Avatar
If still using stock rims and tires it might be a tire rubbing. Happened to me. The rear upper control arm was hitting the tire. Stock rims didn't have enough back spacing. .
Sláinte
Old Feb 5, 2014 | 05:45 AM
Sláinte
thanks, i dont think its my tires. i do have stock rims but i have the 1.5 wheel spacers on them. its not a burnt rubber smell more of a like wire burning or metal getting hot smell.. idk hard to explain.
Old Feb 5, 2014 | 06:10 AM
my front and rear axle breather hose are still connected so it cant be that, idk
Old Feb 5, 2014 | 06:24 AM
Nwapache's Avatar
If you still have the issue when you leave work, then I'd pull the wheels and inspect your assemblies, start with the front axle. It's likely that it's just leftover from yesterday and will diminish completely by the time you get home tonight.
Old Feb 5, 2014 | 06:30 AM
thanks, im dropping it off at the alignment shop in the a.m hes going to check over my work and torque the jam nuts to spec since i could barely get any pull on them.
