Help!
Old Mar 29, 2008 | 11:37 AM
stumpman79's Avatar
Default Help!
My front driveshaft spins when im in 2 wheel drive... it not suppose to unless 4 wheel drive is engaged... correct? What could cause this? Any feedback would be greatly appreciated. Thanks.
Old Mar 29, 2008 | 11:41 AM
HUNTER's Avatar
Nah, your ok. Its spins but isnt engaged at the Tcase...thats the complaint about the drive line drag all the time and switch to front hub diconnects.
Old Mar 29, 2008 | 12:00 PM
GrassSeed JK's Avatar
The JK doesn't use hubs on the front axle so your axle shafts are alway connected to the wheels thus turning your ring gear that turns your pinion that turns the front drive shaft. So what you are seeing is normal. Aftermarket does have an outer hub/spindle setup that uses manual hubs that disconnects the wheel from the axle shaft. The only thing that really bugs me with the axle setup from factory is the parasitic drag (decreases fuel economy) and constant wear of turning parts that don't need to be used when not in 4wd.
Old Mar 29, 2008 | 12:06 PM
CIJeep's Avatar
Expected MPG savings are 1/2MPG with disconnects.
Old Mar 29, 2008 | 12:23 PM
stumpman79's Avatar
Default Reply
Ok... thanks. Ive got a horrrible clanking noise on the transfercase end of the front driveshaft... where the double cardin joint is ( i have J.E. Reel 1350's). The joint is very loose... any suggestions?
Old Mar 29, 2008 | 07:33 PM
goose244's Avatar
Yeah if it is still under warrenty send it back. Sounds like you have a bad u-joint.
Old Mar 30, 2008 | 08:30 AM
stumpman79's Avatar
Thanks. I just sent the rear one back two weeks ago.
Old Mar 30, 2008 | 10:19 AM
Renegade's Avatar
Is the output of the transfer case loose, or is it the double cardan joint?
Old Mar 30, 2008 | 11:22 AM
stumpman79's Avatar
Its the double cardan joint... it feels like there is too much play in it. The drive shaft is securely bolted to the transfercase.
