Help!!!!
Old Jun 5, 2009 | 04:41 PM
MPBoxer's Avatar
Default Help!!!!
I am replacing my passenger upper control arm and the bolt that mounts to the frame will not come out because the exhaust pipe is too close.
I am afraid of bending the exhaust too much because it is so close to the exhaust manifold and I don't want it to crack.
Any suggestions?
Thanks
Old Jun 5, 2009 | 04:44 PM
Robar's Avatar
You have to cut the bolt and replace it with a new one. Only other option is to remove and reinstall the exhaust.
Old Jun 5, 2009 | 04:45 PM
NH4X4's Avatar
If you can get in there with a sawzall or a cut off wheel cut it and put the new bolt in the other way with the nut on the manifold side.
Old Jun 5, 2009 | 04:47 PM
MPBoxer's Avatar
Thanks Robar,
I tried to use the bolt that came with the currie CAs I bought on the driver side but it seems to big. It won't go through the hole closest to the outside. Do I have to drill too?
Old Jun 5, 2009 | 04:50 PM
Robar's Avatar
Originally Posted by MPBoxer
Thanks Robar,
I don't know why the bolt wouldn't fit, if they sent the correct size, but you do not want to drill it out. Get a grade 8 or the metric equivalent in the correct size.
Old Jun 5, 2009 | 04:52 PM
MPBoxer's Avatar
Thanks Guys.
