Help with Adjustable Sway Bar Link
Old Mar 11, 2012 | 03:27 PM
DGriz's Avatar
Default Help with Adjustable Sway Bar Link
I got my JKS JSPEC lift installed this weekend but I'm getting a death wobble from hell sometimes after turning. I've checked all the bolts and everything is tight. The only thing that just doesn't look right is my Adjustable Sway Bar Links. Shouldn't the rubber be up against the sway bar? Here's what mine looks like:
Do I need to drill the hole out so the rest of the post slides through? Could this be the cause of my death wobble?
Old Mar 11, 2012 | 03:37 PM
Rich6700's Avatar
your sway bar links are fine, that's the way they mount. Are you talking about a slow speed wobble?
Old Mar 11, 2012 | 03:48 PM
DGriz's Avatar
Yeah, like under 35 mph but it's not just a little wobble, I have to pull over or I'll lose control kind of wobble. After I stop and then go again it stops. Only happened twice so far. After I made a U-turn leaving the shop and 75 miles later after driving smooth on the highway that whole time, it happened several hundred feet after a left turn in a residential area.
