help on alignment specs
Old Apr 6, 2011 | 06:46 PM
jvandy50's Avatar
Originally Posted by nthinuf
Yep, that ring of grease splattered on the undercarriage above the joint is the give-away. You will want a set of adj arms to set the pinion for the new shaft. (assuming you go aftermarket instead of replacing with a factory shaft).
And assuming nothing is bent, you will want the second set of adj arms to move that side of the axle to even it up. But if you find a bent bracket or something, you will probably want to get it fixed first.
always appreciate your input man. i did not see any bent or broken brackets. but i would definitely say that i am looking with an untrained eye. i am taking it to a more 4x4 friendly shop friday and maybe he will tell me more.
Old Apr 8, 2011 | 08:15 PM
Absolute's Avatar
Here are my numbers. 4.5' of lift with 37s.
Old Apr 9, 2011 | 06:42 AM
jvandy50's Avatar
What setup do you have?
Old Apr 9, 2011 | 08:00 AM
nthinuf's Avatar
Click his screen-name and select 'view profile'.
Old Apr 9, 2011 | 10:02 AM
jvandy50's Avatar
Just have the iPhone app for the wknd so can't see it, at least i don't think I can.
I did take my jeep to another shop Friday and have another printout I will post later. He had some problems with balancing the tires but finally got it better and shimmy is reduced. Thrust angle was not near as bad according to him. He did tell me to keep and eye on the driveshaft and he said my camber was slightly off and I might need offset ball joints in the future
Old Apr 10, 2011 | 05:46 PM
jvandy50's Avatar
Default 2nd alignment check
this guy said he was more worried about my camber than anything and that the shimmy at 65-75 was definitely a tire issue.
kinda hard to read sorry
