Help asap!!!
I'm driving to atl from new Orleans and have stopped in Gulfport due to continuous death wobble... My caster is at 0.0 according to the alignment shop.. Anyway to adjust without adj. Arms?? Please I'm stuck in ms!!
If this is the 1st DW you have experienced and it cam on while on this long trip....that takes out bent parts due to wheeling theory. I would have them check the torque on all the steering components, especially the tie rod ends. Also check your track bar bolts and the area where the track bar mounts to the axel as some of the JK's have been breaking welds. Also some factory steering stabilizers are defective....look for fluid leaks around the steering stabilizer.
Have you ever had it do DW before?
Have you recently put on new tires or steering components?
Thanks for the responses.. I have had death wobble before.. I installed a jks trackbar and tf stabilizer, it went away until now.. I have the 2.5 tf bb..I'm getting adj control arms but to get me to atl an offroad shop used some caster bolts.. Thanks again
If yo udo in fact have ZERO caster cam bolts won't help.... also they will have to drill out the CA mounts to fit cam bolts.... more work in the end. check the trac and the trac braces...
There stealing your money!!!! You have loose bolts somewhere!!!! Most likely your track bar. Simply tightening that bolt will get you back on the road. DW doesn't just appear out of no where on a long trip......the road vibrations loosened a bolt causing your DW!!
if that shop is telling you that you need cam bolts on a BB, go tell the head mechanic to go play hide and go fawk himself. #1 caster is not zero from a BB. no way. #2 adj. control arms the only way you should increase the caster. when the cam bolts give you issues and you get adj. arms, you will have to get washers welded on your brackets to repair what they cut out.
I would go find another shop ASAP. You are just wasting money there.
