HELP! - Compressor switch wiring
Old Jul 6, 2012 | 12:34 PM
JnT's Avatar
JnT
Default HELP! - Compressor switch wiring
I've got my ARB compressor all installed EXCEPT I don't know where the hell to tie in the "ignition source" wire from the switch harness. It has 2 wires, a red and yellow that is supposed to go to an ignition source and a blue one that is supposed to go to the dash lights. Now I don't really care if it lights up or not with the dash lights but it WILL NOT work unless I can get that wire tied into an ignition source.
I used the project-jk write up for reference but it make no mention of the extra wires from the switch harness
HELP!! I wanna get this installed so I can move on to my other items.
Old Jul 6, 2012 | 02:13 PM
river2c's Avatar
You can tap into the wires behind the driver's side cigarette/accessory outlet or an unused ignition terminal on the fuse panel. Another option is to use a switched power source like the **** setup.
Old Jul 6, 2012 | 06:49 PM
JnT's Avatar
JnT
Thanks. Got it figured.
