Help diagnosing a problem
Old Apr 21, 2014 | 05:57 AM
NJ*Spartan's Avatar
Default Help diagnosing a problem
I noticed yesterday my jeep feels different when turning. The best i can describe it is like this: have you ever had your 4wd engaged on a hard dry surface and you get that wheel hop while turning? (No my 4wd isn't on) That's kinda what this feels like, although more subtle. I feel it more on right turns than left. If it matters, I'm running 33"duratracs, stock rims with spidertrax spacers, and a 2" budget boost. I've had the set up for over a year problem free. I'm gonna take it in to get checked out probably tomorrow but I'd appreciate any advice you guys can give
Sent from my Samsung Galaxy IIIs
Old Apr 21, 2014 | 06:22 AM
Rebar-7's Avatar
Does it make any noise when turning ? Maybe axle u joint ! Spring un seated, ball joint.
Old Apr 21, 2014 | 06:23 AM
NJ*Spartan's Avatar
I don't hear anything from inside. Gonna crawl underneath and do a visual inspection today.
Old Apr 21, 2014 | 07:15 AM
ronjenx's Avatar
The steering wheel oscillating back and forth a little when turning in 2wd can be an early sign an axle u-joint is beginning to seize.
Old Apr 21, 2014 | 07:18 AM
NJ*Spartan's Avatar
Ok. Any suggestions to keep in mind of a good replacement u-joint? If I remember right, the stock ones aren't greasable. I'd like to change that.
Old Apr 21, 2014 | 07:26 AM
karls's Avatar
Greasable ujoints are weaker (in theory) than non-greased units since the centers are drilled out for grease passageways.
Old Apr 21, 2014 | 07:30 AM
NJ*Spartan's Avatar
Really? Hmmm...so what's the general recommendation? Greasable or non-greasable?
Old Apr 21, 2014 | 07:35 AM
ronjenx's Avatar
That could be true, but I'll bet we see a lot more u-joint bearing failures than broke X's.
You can drill the end caps and install your own flush fittings. I've been thinking of doing that if I can't find greaseable ones when replacement time comes around.
Old Apr 21, 2014 | 01:06 PM
karls's Avatar
It's mere theory- it would be tough to replicate 'exact' conditions to determine when they would fail but I would agree with Ron- most people will see the roller bearings turn to dust before breaking the center section.
Usually you'll see the outside arms of the cross break off and caps walk out. I was just bringing up awareness of a potential issue, albeit relative in risk to standard joints. I bought nongreaseable since they were what was in stock at the time.
Old Apr 21, 2014 | 01:11 PM
NJ*Spartan's Avatar
My buddy took a look at it today and confirmed the passenger side u-joint is bad. I ended up going with the greasable ones from NAPA. The areas I wheel in are pretty sandy and the "sugar sand" in the NJ Pine Barrens gets everywhere. At least fresh grease can push some of it out...
