HELP, Drive shaft issue
Old Mar 21, 2011 | 06:55 AM
JK-UTE's Avatar
Default HELP, Drive shaft issue
Ok, so I need to pick some of your brains re: possible drive shaft issues. I will try and explain this as best as I can.
To start off, I have an 07 automatic 4 door with a 4" TF lift and I run 35's. I have my stock drive shaft on the jeep. So, here we go:
As I was driving on Friday afternoon, I noticed a clicking sound as I was slowing down. Now the sound is cyclical, meaning as I slow down, the sound slows down. At first, I thought I had a rock or a nail in my tire, sounds reasonable, so when I stopped to fill up ($3.45/gallon... that's another topic), I checked my tires and nothing. The next obvious thing was to check the drive line and I could not see anything.
I got home jacked up the driver's side front tire and was able to spin the tire and I started hearing the click. While under the jeep, I was rotating the tire and I think the clicking sound happens like every three and a half turns of the drive shaft. It appears that the click is coming from the CV joint (transfer case end) of the drive shaft. I tried looking at the CV boot but I could not tell if it was torn, however, there seemed to be a little grease around the CV area, but not a lot.
I'm wondering if I tore the boot on the CV joint and then burned up the splines or something in the drive shaft.
My question is does that sound like that may be the culprit? I realize without actually seeing/hearing the sound it's hard to tell but I'm willing to hear what you all may think.
Thanks in advance...
Old Mar 21, 2011 | 08:50 AM
JK-UTE's Avatar
Youri, thanks for the feedback. I kind of thought that's what it was. I just wanted to see if I was on the right track. I guess I'll be calling Tom Woods here in a few...
Thanks again.
Old Mar 21, 2011 | 09:56 AM
nthinuf's Avatar
Since it's your front shaft, just pull it off and go for a drive. No clicking, and you verified the problem. It will also be better to run without the shaft, 'just in case'.
Old Mar 21, 2011 | 10:00 AM
mrijeff's Avatar
I replaced mine with a Tom woods and it fixed the sound. One test is that the sound should get louder in 4 x 4.
Old Mar 21, 2011 | 01:39 PM
JK-UTE's Avatar
Thanks for your responses. I appreciate it.
Old Mar 22, 2011 | 11:56 AM
JK-UTE's Avatar
New drive shaft ordered. I'll keep you updated, just in case any of you really give a damn...
Old Mar 22, 2011 | 12:23 PM
Olean NY Jeeper's Avatar
Of course we care, let us know how the new shaft works out. I had to replace my rear shaft last month because it was spraying grease all over the place. Better to replace it before it blows. I know u can disconnect it but do you really want to be on the side of highway in winter with trucks driving by u f-ing with ur DS? I know I didnt.
Old Mar 25, 2011 | 07:10 AM
JK-UTE's Avatar
Big brown truck brought me a new drive shaft today. Will let you all know what happens once I get this thing installed.
Old Mar 25, 2011 | 07:58 AM
Erockhopper's Avatar
This exact same thing happened to me last week. Your new shaft will fix it. Just a bit sooner and we could have had a garage party. DOnt no if you have put it on yet but there is a good write up on here about it. I dont know how hard it would have been without the gear puller I rented from AutoZone, but it sure made it easy. $35-$40 deposit and refunded when you bring it back.
Old Mar 25, 2011 | 08:01 AM
rinkishJK's Avatar
make sure u use red loctite on the yoke nuts!
good luck.
