Help, drive shaft is pausing
Old Apr 10, 2009 | 05:16 AM
2climbbig's Avatar
Default Help, drive shaft is pausing
I have been having a jerking motion when making tight turns. I ran along the side of my jeep as my son made tight turns to see if I can see the problem. The drive shaft was not turning at a constant velocity. It looked as though it would pause and then speed back up. Timing was consistent with the jerking motion of the jeep. I do have an Aussie locker in the front.
I thought perhaps this had something to do with the wobble I am getting at high speeds.
Old Apr 10, 2009 | 05:20 AM
roguejk's Avatar
Front DS or rear?
2wd or 4?
Old Apr 10, 2009 | 05:25 AM
paramaniac's Avatar
Originally Posted by roguejk
Front DS or rear?
2wd or 4?
X2 on those questions and is there a chance either:
A) ur locker is engaged
Or
B) ur in 4wd?
Old Apr 10, 2009 | 05:27 AM
Rhino64's Avatar
On the Northridge site it states the Aussie has not been tested on the new JK's yet. Thats probably the problem. I know a lot of people have still installed them but thats why I'm waiting.
Old Apr 10, 2009 | 12:02 PM
2climbbig's Avatar
its the front dirve shaft and its in 2wd. I have a video of it, but not sure how to post it. The pause is not consistant. It will turn at a constant speed for a few seconds, and then just pause.
Old Apr 10, 2009 | 12:09 PM
bigbluejk's Avatar
I didnt like the way my aussie felt in the front so I had it yanked. It felt like it was engaged all the time or something. Are you sure it was shimmed correctly?
Old Apr 10, 2009 | 12:31 PM
2climbbig's Avatar
I used thrust washers off a YJ as they were slightly thicker than the TJ ones I got from Dave. It put the locker into spec.
Old Apr 10, 2009 | 12:35 PM
2climbbig's Avatar
I will put up the video on you tube and post the link in two hours.
Old Apr 10, 2009 | 12:44 PM
Rhino64's Avatar
Why don't you go over to the torq-masters web site and shoot them a email describing the problem. I'm sure they can tell you whats wrong. Probably a defective locker.
Old Apr 10, 2009 | 02:52 PM
2climbbig's Avatar
Here is the link... you can clearly see the pause around 20 to 25 seconds into the video
http://www.youtube.com/watch?v=BqvJoH6acRA
