Help! I got the wrong carrier shims rear (G2)
Old Jun 17, 2012 | 04:40 AM
Micke's Avatar
Default Help! I got the wrong carrier shims rear (G2)
Hello!
I have just received the gears and installation kits from G2. I have a JK Unlimited Rubicon 2008. When I pulled out the carrier the shims are located outside the bearings, just as I thought. The shims are quite large. In the kit (35-2053) the shims are much smaller, are they supposed to be mounted on the other side of the bearings? Which JK Rubicon has this setup?
The shims that I got for the rear is marked with "SK 23". For the front I got the larger ones marked "SK 47".
Is it safe to buy a shims kit marked "sk 47" and use it for the rear? I don't want buy a whole new installation kit.
Thanks guys!
