HELP! Im considering 33 12.5 15's
Old Sep 2, 2014 | 02:58 PM
johnmarrero77@gmail.com's Avatar
Default HELP! Im considering 33 12.5 15's
Considering 33 12.5 15's on my 2010 Dr stock jeep. Do I need to make mods, any words of advice, will they kill my gas mileage? I'm going for all terrains. Advice as in good tires and rims for mostly highway and city. Thanks!
ID:	574168   Click image for larger version
Old Sep 2, 2014 | 03:40 PM
nthinuf's Avatar
For 15" rims, you want a low enough backspace that the rims will clear the calipers. No more than a 4.0", but a 3.75" or lower would be better. DiscountTireDirect has a list of 15" wheels that they gaurantee will fit, that might be a good place to start looking. (a quick search should find the thread where these rims are listed, or call them)
Old Sep 3, 2014 | 11:29 AM
immortalmetal's Avatar
Don't get 15". I was guaranteed a wheel I would get would clear. And it had 3.75" of backspacing. It was steel procomp wheel. It still rubbed and shaved the calipers. Only the front though.
Safest is to just stay away from 15" wheels. There's never a guarantee with them
Old Sep 3, 2014 | 11:39 AM
nthinuf's Avatar
This is the thread I was referring to.
https://www.jk-forum.com/forums/spon...wheels-120933/
Old Sep 3, 2014 | 12:00 PM
rvator's Avatar
I bought a single wheel I wanted,tested the fit and then ordered 4 more and five tires no big deal.
Old Sep 3, 2014 | 12:01 PM
rvator's Avatar
US wheel 15x8 d window Daytonas with 4 inchbs
Old Sep 3, 2014 | 03:47 PM
Wordzero's Avatar
I just recently put 15's on mine. They're procomp rock crawler 52's. Fits perfect with zero rubbing. Those paired with 33x12.5x15 Mickey Thompson MTZ's. Looks great!
Old Sep 3, 2014 | 03:52 PM
PG-JKU's Avatar
DO IT!
I love my 33x12.5x15 Duratracs!
I took a chance with some Ion Alloys. Clears the calipers without any issues.
Disclosure: I have a 2.5" coil lift. You can probably do this without the lift as long as you have proper backspacing. The BS on the Ion Alloys is a bit extreme - probably around 3.7". You might need to trim fenders for full stuff without a lift.
Name:	Bill Cheung for January.jpg
ID:	574306Click image for larger version
Name:	jeep front tire.jpg
ID:	574307Click image for larger version
This is the jeep after I removed the bumpstops that came with the kit. I'll put them back in if I ever go with 35's and decide to keep the fenders stock. This is also with proper length Bilstein 5100's.
Name:	Jeep back end 2014.jpg
ID:	574309Click image for larger version
Old Sep 3, 2014 | 04:00 PM
tapcola's Avatar
WHY WOULD YOU GO 15s?
Old Sep 3, 2014 | 04:05 PM
PG-JKU's Avatar
More sidewall to flex over obstacles, 15" tires are generally less expensive, I think it looks sweet, and better in the bush than having 18's or 20's with very little sidewall.
