HELP...LED Headlights wont stay on!
Old Apr 19, 2016 | 05:24 PM
jstikel3's Avatar
Default HELP...LED Headlights wont stay on!
Hey guys I am having a very frustrating issue with my new LED headlights. Please help me as I cannot figure this problem out. I received a set from a vendor on here and they lights work great until I turn the vehicle on; they cycle on and off a couple times and then shut off completely. They are not flickering they shut off for a second or two then back on until the ECU completely shuts power to them.
I have spent hours on the phone with the owner of the shop who has been absolutely dedicated to helping me figure this out. It is not a loose connection and it is not the antiflicker harness. He sent me another set to try and solve the problem with no luck. I have hooked the light directly to the factory connection without the harness and had the same result; they stayed on fine until I turned the vehicle on.
I gave up on these headlights and ordered another set of VERY WELL known and respected headlights that have the antiflicker built in and specifically designed for the JK. What do you know I had the same exact issue.
So whats the deal? Has anyone had issues like this or does my ECU just not want to accept the fact I would like to see driving down the road.
Please help me figure this out as it is becoming very irritating.
Here are a couple videos the illustrate the difference. And yes I know my TOB is making noise, I am about to ask your opinion on that issue as well in another post.
https://www.youtube.com/watch?v=XUyYlBSvGH0 https://www.youtube.com/watch?v=gWAWbfeGgKY
Old Apr 19, 2016 | 06:19 PM
BlackRockBurner's Avatar
Try disconnecting every aftermarket connection at the battery and if you tapped into the cigarette lighter. Bring it back to stock.
Old Apr 19, 2016 | 08:04 PM
shabbernigdo's Avatar
dose it do the same with stock headlights? you may end up having to use a stand alone wiring harness.
Old Apr 20, 2016 | 04:19 AM
jstikel3's Avatar
I will try this today. Good idea. I am going to contact the manufacturer for the 2nd set of lights since those were made in the US.
Old Apr 20, 2016 | 04:22 AM
jstikel3's Avatar
Nope never had any issue with the stock headlights. The 2nd set I bought directly plug into the factory headlight and have the anti flicker built in.
Old Apr 20, 2016 | 07:43 AM
Pull one of the lights and test the harness and see if you are getting constant power also check your grounds ive seen a missing ground cause all kinds of weird electrical issues on newer vehicles. It really dose look like its a controler causing the problem
Old Apr 20, 2016 | 08:12 AM
dr.dirty's Avatar
You wont get a constant reading that way. The headlights are fed by PWM. My Jw speakers and my truck lights do the same thing on occasion. Never found a reason why they do it and sadly they have decided to go off while driving on the freeway at night. The funny part is its the exact same blink sequence as the OP posted.
Old Apr 20, 2016 | 10:43 AM
I have some trucklites on a rallylights standalone harness triggered by the factory lighting circut and have never had this issue. mines a 2012. maybe they changed something for the newer models on the pwm.
Old Apr 20, 2016 | 03:37 PM
jstikel3's Avatar
The second set of headlights are the JW Speaker Evo J. They do the same thing as the other headlights did. These were designed for our JK's. I tried to contact JW today and didn't receive a call back. When yours cycled on and off did they eventually go out completely?
Old Apr 21, 2016 | 07:09 PM
jstikel3's Avatar
Any more advice on what to try. I have tried to get in touch with JW Speaker but haven't heard back. I have a 07 if that makes a difference.
