Help with lift install
Old Sep 1, 2011 | 11:49 AM
dmick33's Avatar
Default Help with lift install
I just got my 3 inch premium plus full traction lift and have a couple questions. The kit came with adjustable front and rear upper control arms and adjustable front and rear track bars. so question is does anyone have this lift and know the lengths I need to set these at to get proper alignment and ride?
Old Sep 1, 2011 | 02:51 PM
Full-Traction Suspension's Avatar
Former Member
You need to set the control arms to the stock lengths, 18 3/4" for the front and 17.5" for the rear. Then adjust to correct the pinion and caster angle. On the upper front thread the heim all the way in. This will get you around 4.5-5 degrees of caster.
Set your trackbars about 1/8" longer than stock.
Please call or email me if you have questions.
Old Sep 1, 2011 | 03:06 PM
dmick33's Avatar
Is there a measurement to set the rear arms to?
Old Sep 1, 2011 | 03:19 PM
Former Member
17.5" is the starting. You need to adjust the pinion angle after this. Please call me. I'll explain
Old Sep 1, 2011 | 04:03 PM
dmick33's Avatar
what's the number?
Old Sep 1, 2011 | 04:46 PM
Former Member
what's the number?
We are closed,
PM me your number and I'll give you a call.
I'm off tomorrow and will not have Internet or reception until Tuesday. ( going wheeling )
