View Poll Results: Which gear on a 6 speed with 35" tires
4.10
1
2.44%
4.53
6
14.63%
4.88
34
82.93%
Voters: 41. You may not vote on this poll
Help me decide which gears
Hello everyone, maybe this thread has already been posted but I cannot find it. I was wondering which gears would be appropriate for my Jeep
Current Spec's
Standard 6 speed
35" Tires
Factory 3.73 gears
Since putting on these tires 6th gear is non existant on any type of hill and sometimes even 5th gear is not good enough.
Feed back will be greatly appreciated
Current Spec's
Standard 6 speed
35" Tires
Factory 3.73 gears
I have the same setup… most people, as is evident from the poll recommend 4.88s but I’m wondering if that’s overkill? Is anyone rocking the 35’s/6-speed/4.88 and can say what your RPMs in 6th gear are at 65 mph?
3.73 (Dif Ratio) / .84 (6th gear) = 4.44, the equivalent of your 1:1 5th gear.
4.56s are within 2.7% of where you already are on the downshift so that doesn't at all sound like where you want to be.
4.88s or higher are where you want to start.
it seems a counter intuitive, but the lower gears get the RPMs up in the power range that the 3.8 likes, so it stays in OD on the highway, and you get better milage, better in town performance, and better wheeling performance
I would go 5.13 or 5.38
