Help me understand gears and ratio's
Old Dec 16, 2011 | 05:02 PM
blue project's Avatar
Default Help me understand gears and ratio's
I have a 2010 sport 2dr w/ auto trans. It came with the steel wheels. Am I correct in assuming that I have a 3.21 gear ratio? Also I will be running 33's for the rest of its life. Safe to assume regearing is a good idea? From the chart on here I think I should run 4.88? Thanks for the help.
Old Dec 16, 2011 | 05:15 PM
ronjenx's Avatar
Your automatic came from the factory with 3.73 gears.
Have you had it since new?
Old Dec 16, 2011 | 05:17 PM
Surf City Dan's Avatar
JK owners with automatics normally run a deeper gear than manual transmissions. Because they are geared differently and run at different RPM's especially at highway speeds. I know with 35's, its seems that there are quite a bit of auto's running 513's and they are very happy. I would think that 488's would be a good choice for 33's. You will notice a huge power increase over your stock gearing. If you are looking for a slight fuel mileage increase over 488's then you might get that with 456's. And the power will still be good just not as snappy off the line.
Old Dec 16, 2011 | 05:19 PM
I have has it since new. Running a 31" tire now it goes ok but stepping up tp 33's and I do tow I figured I need to upgrade.
Old Dec 16, 2011 | 05:22 PM
ronjenx's Avatar
I have 4.10 on 32's. Adequate, but not great. I would agree with Surf City Dan's post.
