HELP me wheels 5 x 5.5 bolt
Upgrading to SOLID D60 which require 5x5.5 wheel bolt patteron. Currently running Mickey Thompson Classic II 17 x 9 / 5x 5 / 4.5 back spacing with 35 MTZ...
Looking for wheels to fit 35" MTZ with 5x5.5 bolt and minimum 4.5 backspacing. Does AEV wheels fit the SOLID Spyntec hub
Which wheels should I go for..
AEV wheels will not fit. They do not make a 5x5.5 bolt pattern, and also the center hole for the hub is not wide enough to be able to have the licking hubs.
I think you could get another Mickey Thompson, or pretty much any wheel designed for a CJ. Should be quite a few out there depending on the style you like.
If you like your current wheels Quadratec sells the 17x9 MT in 5 x5.5 pattern
http://www.quadratec.com/products/92605_00X_C_PG.htm
