help needed
Old Sep 2, 2010 | 02:39 PM
Mozjeep's Avatar
Originally Posted by NGINIER
Both of these kits are well built and will handle high speed trails. However, at high speeds, you'll definitely want to look at gas variable resistance type bumpstops(both RE and Tera make these I believe, Tera makes the speedbump) You'd also want to consider better shocks on both kits or even coilovers. Remember, different shocks/coilovers would work WITH a long arm kit and not INSTEAD of a long arm kit. And on an even more extreme end, if all you are doing is high speed, maybe you want stiffer sway bars too... but you can ponder that one later...
i think i am going for teraflex 4" lift with bump stop kit. what do your think of king shocks as compred to fox or elka?
Old Sep 2, 2010 | 03:16 PM
jeepoholic's Avatar
I've heard the Elka shocks are out of this world smooth ride at high speeds.
Old Sep 3, 2010 | 09:34 AM
NGINIER's Avatar
That's tough, they all are great shocks, but once again, its more than that. I've heard great things about the ELKA's as well as the Kings offered by ORE(they did testing and specifically valved these for the JK's) I haven't been too impressed with the FOX shocks on the JK's I've seen but that could be just improper valving. both ORE and TF are sponsors on here and could get you set up appropriately.
Have fun out there and be safe!
If you're really going to be doing high speed and really do have unlimited funds, I'd look into axles next. Even with gussets, shafts, etc, high speeds put a lot of stress on axles, especially with larger tires... Just a thought... It sounds like you're on your way.
