Help needed: Abs
Old Jun 26, 2012 | 02:18 PM
SoDak JK's Avatar
Default Help needed: Abs
I was on my way to my work the other day, taking the interstate, going in a straight line no bumps and my abs kicked on. scared the SH** out of me.... wondering if anyone know what would have caused this?
Old Jun 26, 2012 | 02:22 PM
robinson86's Avatar
Is your steering wheel centered dead nuts? Did you have a lift installed recently or hit something?
Old Jun 26, 2012 | 03:13 PM
SoDak JK's Avatar
just had it alignment, lift professionally installed and haven’t hit anything with it
Old Jun 26, 2012 | 03:21 PM
HeyBob's Avatar
Yeah I would still check the steering wheel for being centered. Even doing it by wol's write up it took a few times to get mine spot on. Even a little off in either direction can cause the abs to trigger. And the alignment shops don't always look to recenter the wheel.
Old Jun 26, 2012 | 05:28 PM
ricksjeep10's Avatar
Agree with the centering steering wheel comment. Mine was off a little to the left after lift install. I overcorrected and with the wheel a little off (~ 10 degrees) to the right the abs went nuts.
