Help needed with Front Lower Flexarm install...
Old May 2, 2009 | 05:01 PM
ssmathis's Avatar
Default Help needed with Front Lower Flexarm install...
I'm trying to finish my install today but I can't get the passenger side flexarm to lineup. The drivers side was fine but no matter what I do the front axle is about 1/2" too far back. Any thoughts would be greatly appreciated.
Scott
Old May 2, 2009 | 05:10 PM
mkjeep's Avatar
Got any rachet straps and a floor jack? jack your axle up a bit to get the weight off and hook a rachet strap to the axle and the to frame or bumper. Tighten and get a big screwdriver to put in the hole to help it line up . Also may take abit of goin back and forth from jack moving to rachet strap to screwdriver, if your doing it by yourself. Kicking the crap outta the tire helps aswell.
Old May 2, 2009 | 05:12 PM
mkjeep's Avatar
Also make sure the bolt on the frame end is not very tight, just in there with the nut started.
Old May 2, 2009 | 05:23 PM
ssmathis's Avatar
Thanks. This may be a dumb question but should the tires be on to put these on?
Old May 2, 2009 | 05:55 PM
mkjeep's Avatar
Yes! No need to take tire off to install, plus gives you something to kick.
Old May 2, 2009 | 05:58 PM
mkjeep's Avatar
But if you got the frame up on jack stands no tires and a floor jack under neath the axle, just use the rachetstrap screwdriver method No kicking while on jack stands.
Old May 2, 2009 | 06:20 PM
ranwitscissorz's Avatar
Scott
Put the jack on the pumpkin near where the driveshaft connects, it should rotate it some towards your control arm.
Old May 2, 2009 | 06:22 PM
ssmathis's Avatar
Thanks. I've quit for the night but will try it again in the morning.
Old May 3, 2009 | 11:08 AM
ssmathis's Avatar
Got everything put back together this morning, thanks for everyone's help.
Old May 4, 2009 | 08:51 AM
ssmathis's Avatar
Just a picture after getting everything done yesterday. Thanks again for the help.
Scott
