Help please. Weird steering wobble...
Old May 14, 2015 | 03:12 AM
nismosis's Avatar
Default Help please. Weird steering wobble...
Hi all. I have just recently started noticing a weird wobble feeling when I am taking slow turns. It kind of fees like taking a turn on dry pavement in four wheel drive. I feel it right in the steering wheel, almost like a bounce. When I drive straight or faster it is fine, I don't notice anything. I checked my power steering fluid, which was fine. I though maybe my pump is starting to go. If I had to pick a side I would say it's coming from the driver front side turning either way. I jacked the jeep and didn't notice any movement that I could see. Maybe ball joints or tie rods I don't know.
Just thought I would see if anybody has an issue like this. I have an 08 wrangler two door with a 4"rough country lift. I've been running this lift for about 5 years with zero issues. Thank you.
Old May 14, 2015 | 03:14 AM
nismosis's Avatar
I guess I should say this. Over the winter I had to plow through the end of my driveway and got stuck in about 4 feet of snow. Had it packed pretty good. Possible alignment issue? It's just weird how I only notice around corners.
Old May 14, 2015 | 04:49 AM
kjeeper10's Avatar
Vet Army
U-joints ?
Old May 14, 2015 | 04:54 AM
Offroad_Elements's Avatar
Former Vendor
Originally Posted by kjeeper10
U-joints ?
X2^^^ Check u-joints, sounds like they're binding up.
Old May 14, 2015 | 01:27 PM
nismosis's Avatar
Thanks. I will check it out. Is there an easy way for me to diagnose if they are bad?
Old May 14, 2015 | 03:15 PM
Mr.T's Avatar
Community Favorite
I'd park it with the wheels turned far right or left, in 2WD, then jack up the front and spin each wheel by hand. Watch each u-joint and feel how smooth it is to turn the tire.
Old May 15, 2015 | 03:10 AM
nismosis's Avatar
Thanks for the help
