Help! Push button start?
Old Oct 19, 2022 | 09:22 AM
snkbitn1's Avatar
Default Help! Push button start?
I have been dealing with the dreaded click no start issue for several months. I think the range sensor finally gave out. Will not start. So… I am trying to wire in a momentary push button start to bypass the trs to start the jeep. Has anyone done this that can help me with the wiring?? My jeep has been down for a week.
Btw - 2007 JKU 3.8
Old Oct 20, 2022 | 05:32 AM
Starwarsobio's Avatar
Default Push button install
I have the click no start and had the tipm rebuilt which cost a lot , got rid of other issues but not the click one. So pull the starter relay out of the fuse box . Take two long wires and strip the ends. Twist to fine points so you can put one wire end into the always live hole. The other wire end goes into the solenoid hole. Also unhook battery. The always live wire should have a fuse installed. Then run wires down the inside of the passenger fender around door frame across top of dash to drivers side. Pull side cover off dash and also drill a hole into dash to mount push button. First connect wires to button and pull thru the hole and fasten. Make sure all wires are placed not to get pinched etc. Put side cover back on and connect battery. To start you turn key and hold to start position. Push the button still holding key and as engine starts release both at same time. I’ve had this for two months. Perfect
if you want pictures send me your email address as I can’t seem to upload any to this response
Old Oct 20, 2022 | 05:43 AM
Default Details
Also I put some electrical tape where I pushed the wire ends into the holes. Just to keep them apart and in place. I also took side cutters and notched a spot at the side of the fuse box to pull wires thru so the fuse cover will close properly.
Pictures would help but I can’t seem to upload. Email me at Warwickavenger@gmail.com if any are wanted
Old Oct 20, 2022 | 10:02 AM
Default Wires for button
They are 87 and 30. Also 30 is always live so put a inline fuse just in case. Solenoid is 87
Old Oct 20, 2022 | 10:42 AM
snkbitn1's Avatar
Awesome. Thanks email sent
Old Oct 26, 2022 | 03:37 PM
snkbitn1's Avatar
Default New issue
Ok. Switch installed. Battery crapped out, tested at only 9 CCA vs 650 as advertised. Napa warrantied a new battery. All was good, started right up!
Now I have developed a new issue. After driving, turn it off to run into a store or something, come back and it won’t restart. No clicking or anything! If I wait 30-45 minutes, it will start with the button. I’m thinking something to do with the anti-theft?? Any thoughts??
Old Oct 27, 2022 | 09:12 AM
Default New issue.
Disconnect the 12v wire from TIPM and connect to the battery. Make sure your turning and holding the key at start position before pushing button.
Also put a brake light type bulb inline with the wire going from button to the tipm. That will tell you if power is going to solenoid when button is pushed and your getting the click
Old Oct 27, 2022 | 09:27 AM
Default Why a bulb
Better than a meter. Put bulb on dash. When button is pushed it lights up. Also in mine when I got a click my bulb would be bright barely a second then go dim. When it started bulb when be bright till button was released. My thought is that that the module on the drivers side that is wired to the TIPM thinks the Jeep has started and is cutting the power too early. Maybe corrosion
Old Apr 17, 2024 | 03:47 PM
Default Pictures
hi there it’s pouring outside so I will take pictures tomorrow. Also I recently changed the range sensor. I now have back up lights and cruise but no normal start
Btw - 2007 JKU 3.8
