Help with rear driveshaft
So I bought some Tom woods driveshafts. I go to to take the rear driveshaft off and it would not come off at the diff!!! And before you ask yes I took all the bolts out. And as far as I could tell there was no real good place to pry it off. Anyone have a tricks or tips to help?
If ya look on the pumpkin side of the flange there are 2 holes 180* appart (in addition to the 8 threaded holes). Use a hammer and flat end punch thru those 2 holes and tap a bit thru 1 then rotate the shaft and tap thru the other. You'll slowly but surely walk it out.
