Help with seatbelt light
Im installing 3 point harnesses so i took out my stock seatbelts. I figured out how to make it not beep, but i have a seatbelt light on and i think an airbag light on.....................any ideas?
connect the wires that complete the circuit for the belt alarm?
leave the female piece in and go buy a seatbelt clip (male) piece from a junkyard. click the pieces together and tie them under the seat. Should solve the problem.
is that the only way? i have my back seats out as well as the carpet and think that might look a little shitty. However if thats all i guess it will have to do thanks
Dunno about ours, but like the above poster stated, making a complete circuit turns off the warning for most vehicles. So you take the 2 wires going to the latch and connect them.
There is a thread on here for seatbelt light disable. Some have said it has worked but it didn't for me. I just cut the male portion off and plugged it into the female portion.
okay....................so i cut off the clicker part of the belt and connect those two wires together? do i have to do anything with the connector that goes into my stock seat or the connector that the old seatbelt connects to?
