Help set up a severe duty Ruby on 37's for the ROCKS
Old Dec 22, 2006 | 08:59 PM
over's tj's Avatar
Default Help set up a severe duty Ruby on 37's for the ROCKS
I have a friend who has a Rubicon auto trans 2 door on order (will be ordered next week now that Mygig is avail)
I am helping him set it up for severe duty in the southwest "PHX" area.
I have a good idea of what we need to do to it to run 37" or possibly 39" BFG Crawlers, but we would welcome any input on the build (his budget is in the higher $ range for build)
we are open to specific product ideas if proven high quaility and tested
"I hope this thread will also be valuable to others, at least in the months ahead"
we have hoist and nice shop to work at
would like to keep wild fabrication to a minimum
this Jk is going to be built as a serious trail/rock rig as soon as all the good parts have panned out in the aftermarket
(ie. proven engineering in time and testing, not just get it ready for SEMA)
Thanks............
We are taking it to Moab for Easter, but I don't think all the needed aftermarket parts will be available by then
Old Dec 22, 2006 | 09:46 PM
dhoffroad's Avatar
well if you want to get serious then find a shop that will do a full out 4 link with coil overs....I personaly would'nt go any larger than 37's on the stock rubi axles but that's just me. I know you said you'd like to keep "wild fabrication" to a minimum but you said you had a budget of 15 g's for the build a good shop could hook you up sweet for the money you have to spend....hell if you lived here in nor cal my shop could hook you up nicely
Old Dec 22, 2006 | 10:31 PM
over's tj's Avatar
Thanks, we love to do as much work on our rigs as we can, its a bonding experence you know, agreed on the axles but you never know, it could end up with Dynatrac Pro-Rock 60's at some point, for now, likley stock housings with chromo shafts and 4.88's
the need for extreme fabrication should diminish as the aftermarket catches up, could you ever of imagined what is available for TJ's now, back in the late '90's
