Help with shaking
Old Jun 16, 2016 | 09:41 AM
blackhawkspkane's Avatar
Default Help with shaking
After installing my 3.5” lift the front of my jeep shakes up and down like a stutter for about 1-3 seconds when i hit speed bump or sewer grate. I think its the springs but I’m not completely sure.All bolts have been checked twice to make sure they’re properly tightened. And its not DW.
Old Jun 16, 2016 | 02:00 PM
sa29560's Avatar
This will either sound ridiculous (superstitious), but torquing versus unbolting and then torquing?
Tires all aired up correctly, balanced?
I have 3.5" of lift as well. You have 35s?
Old Jun 16, 2016 | 07:40 PM
T&ERun's Avatar
If it's not DW, I would guess you have a bad shock. Unbolt the lower shock mounts, tie them out of the way and go for a short drive. See if or how it changes and report back.
Old Jun 16, 2016 | 08:19 PM
casamtb's Avatar
Do you have a raised front track bar and DL flip? It may be the bump steer. I had a similar effect u described. It seemed to be more prominent when I hit bumps that crossed both tires like speed bumps and bridge grates, etc. Do you notice the steering wheel kicks left when u hit bumps. If so it may be bump steer.
