Help. Stuck on the side of the road...
The first one that was replaced bu Chrysler for the original owner was a rod or something. The one that I replaced had a bad number 5 cylinder and piston that was allowing oil to get by. This may have been caused by a bad overheating I had in traffic on the interstate. The radiator fins did have some dirt in them that could have been limiting air flow. So I guess I can take the blame for that. I have been in plenty of mud before with other vehicles and never had this happen though. The oil blow by is probably the cause of the bad cats though. I have had some things change in my life like a separation and moving to a condo without a hose or anything and hadn't cleaned the radiator like I could have, but I was doing more with my kids and life at the time because that was more important than the Jeep. So like I said, I will take the blame for the second motor even though I believe it should have lasted.
Sent from my SM-N900V using Tapatalk
Kudos to your priorities! With your jeep however, maintenance is essential for any vehicle. As for bad cats, a motor less cared for could contribute to that. Bad rings are usually indicative of dirt intake (bad or improper air filter), infrequent oil changes, overheating, etc. Every vehicle I have owned states in the manual to be sure to clean and inspect after any heavy water, mud or sand exposure. It's an engine, it doesn't care for itself. Additionally, mud in the radiator? Those fins need to be clean to dissipate heat. $.75 at a car wash with gentle pressure would have helped.
All I'm saying is engines don't typically fail that often unless care wasn't in place. No judgement, but as an owner of a vehicle, we are responsible for the care and maintenance of that vehicle. You have kids, a vehicle in good running order is important if they are in it, don't you think?
Kudos to your priorities! With your jeep however, maintenance is essential for any vehicle. As for bad cats, a motor less cared for could contribute to that. Bad rings are usually indicative of dirt intake (bad or improper air filter), infrequent oil changes, overheating, etc. Every vehicle I have owned states in the manual to be sure to clean and inspect after any heavy water, mud or sand exposure. It's an engine, it doesn't care for itself. Additionally, mud in the radiator? Those fins need to be clean to dissipate heat. $.75 at a car wash with gentle pressure would have helped. All I'm saying is engines don't typically fail that often unless care wasn't in place. No judgement, but as an owner of a vehicle, we are responsible for the care and maintenance of that vehicle. You have kids, a vehicle in good running order is important if they are in it, don't you think?
Agree 100% with Jeepstin....
as a matter fact I believe that the maintenance we do to our rigs should be as a preventive measure
Not to fix something that has already broken.
not even talk about some people that complain about their jeeps after not doing a single check in 5 years....
the only problem in my case is that when I take somethin apart an put it back together , end up with
some bolts, nuts in my pocket that I forgot to put back....LOL.LOL
Agree 100% with Jeepstin.... as a matter fact I believe that the maintenance we do to our rigs should be as a preventive measure Not to fix something that has already broken. not even talk about some people that complain about their jeeps after not doing a single check in 5 years.... the only problem in my case is that when I take somethin apart an put it back together , end up with some bolts, nuts in my pocket that I forgot to put back....LOL.LOL
Air filter was clean and the radiator area always gets sprayed off at the car wash, but really without removing the top shroud/cover and getting down in there good, you are missing out on cleaning about 55% of the actual radiator fins. The only part you can spray off is what is behind the fan and that doesn't even work out the best. I would suggest pulling the entire radiator out once a year if you were in as much deep muddy water as I have been in. I am a kid when it comes to a mud pit, but those days are over.
Ordered the entire Y pipe, including the 4 catalytic convertors from Amazon for $396. That's a $100 or so cheaper than anywhere else I could find it. Stealership wanted $1100...lol
