Help Suspension questions
I just had OME springs and shocks installed on my 08 4dr Rubicon. The dealer removed the front cross-member with the transfer case skid guard. Something about the front drive shaft rubbing. The lft is only two inches. Should I ask for it to be reinstalled?
Thanks
Bob (Snoopy) Biegel
Thanks
Bob (Snoopy) Biegel
first off,welcome to the forum...
secondly, post up a pic of where this piece was removed from....
thirdly, get it back from them ASAP, a crossmember? im no engineer, but any kind of cross member is usually important
i just had ome springs and shocks installed on my 08 4dr rubicon. The dealer removed the front cross-member with the transfer case skid guard. Something about the front drive shaft rubbing. The lft is only two inches. Should i ask for it to be reinstalled?
Thanks
bob (snoopy) biegel
Thanks
bob (snoopy) biegel
reinstall that asap and I dont think with 2in lift you will rub the transfer case skid on 4dr, some people have had trouble with 3in lift rubbing and ripping off the boor on the driveshaft, you can just notch the skid so it wont hit or get new aftermarket driveshaft which wont rub
If it is just the T-Case skid that was removed, get it back and cut out a notch for the driveshaft before you reinstall it. The other area to watch is the corner of the transmission, as your driveshaft may also contact it under articulation.
Budget for an aftermarket front driveshaft at some point.
