Help with Teraflex 3" Lift
Im about to buy the teraflex 3" coil lift kit,
Bilstein 5100s, and teraflex monster front trac bar.
I cant afford a full control arm kit now.
Im going to run 35 12.5 17's
Will i be satisfied running this setup without aftermarket control arms??
Anybody running the above setup without adding aftermarket control arms???
ride quality and handling acceptability is 100% subjective and some will find it to be fine and some not. i would just install it and, if you feel that your ride is too flighty at highway speeds, get a pair of front lower control arms to help add a bit more positive caster. that should be all that you need to address it.
also, being that you have an auto, you really need to include a new front drive shaft in your budget.
