help with teraflex 4 in. lift???
Old Feb 12, 2010 | 09:10 AM
ryant's Avatar
Default help with teraflex 4 in. lift???
thinkin about getting it with out their flex arms just the simple 4 in. lift and running 35 in. tall tires. but do i need to do any drivetrain modifications??
Old Feb 12, 2010 | 09:15 AM
TeraFlex's Avatar
Sponsoring Manufacturer
You will not be able to adjust the caster without atleast a set of front lower control arms. How tall of tires are you going to run?2dr or unlimited? Yes at some point you will need to replace the driveshafts.
Old Feb 12, 2010 | 09:27 AM
ryant's Avatar
ohh i cant use the stock arms?? and i was gunna run 35 in. tall tires then wen i have enuff money i was gunna re gear it and do driveshafts and 37 in. tall tires all at the same time... probably wen the 35in. tall tires run outta tred
Old Feb 12, 2010 | 09:29 AM
TeraFlex's Avatar
Well you can but at this height of a kit, you really shouldn't.
sully151's Avatar
If you are only running 35's, you might look at the 3" lift. Mine runs pretty tall, more like everyone else's 4". Then you shouldn't need any Driveshaft mods on an unlimited, not sure about a 2 door.
artpics's Avatar
as joe said get a set of front lower control arms my 2.5 coil lift drives so much better with them
Old Feb 12, 2010 | 09:32 AM
ryant's Avatar
yeah its an unlimited rubicon i have like a 1.5 in. body lift rite now so with the 3 in lift will i be able to stuff 37in. tall tires? because that is my goal eventually and i dont wanna change lifts and all that
Old Feb 12, 2010 | 09:33 AM
ryant's Avatar
do you have a picture of yyours??
Old Feb 12, 2010 | 09:42 AM
TeraFlex's Avatar
You can run 37's with a 3" kit. Look up planman here, he has lots of good input on small lift/big tire setups.
Old Feb 12, 2010 | 09:48 AM
ryant's Avatar
what is planman????
