Help from those running 37's needed
Old Oct 30, 2012 | 01:21 PM
Rooster454's Avatar
Default Help from those running 37's needed
I am moving up to 37's next week and can't decide on what backspace to run so that I don't hit the frame or CA's at full turn.
I'm running 4.5 with my 35's now and am thinking closer to 4.0 or 4.25 might be better ??
Any input is much appreciated as I am trying to avoid running spacers
Thanks.
Old Oct 30, 2012 | 01:25 PM
White-JKU's Avatar
I ran 3 on mine and would still hit. Had to adjust the steering some but then I was fine
Old Oct 30, 2012 | 01:33 PM
bob-o's Avatar
I'm running stock Moab wheels with spidertrax 2" spacers and put 3 washers in each steering stop and my tires don't rub the frame at full turn anymore
Old Oct 30, 2012 | 04:15 PM
JKZinger's Avatar
I am running 3.5 inch backspace and don't rub with my Nittos.
Old Oct 30, 2012 | 04:31 PM
jaydoc1's Avatar
Where did you find 2" Spidertrax spacers? They only make up to 1.75" spacers for the JK as far as I know.
Old Oct 30, 2012 | 05:02 PM
tcdawg's Avatar
I run the 37" MTR's in a 4.5" bs wheel and a 1.5" Spidertraxx spacer. I still have to have 1 washer on the steering stops to stay out of the CA's.
Old Oct 30, 2012 | 05:29 PM
jeep2007's Avatar
I run 37 mtr. 4.5 and 3 washers per steering stop. No rub.
Old Oct 30, 2012 | 05:49 PM
bob-o's Avatar
Oops I'm sorry I meant 1.5" spacers
Old Oct 30, 2012 | 06:06 PM
ttechris's Avatar
I'm running 3.75 BS on 37x12.5 mtr-k without any issues. My old 4.75bs would rub a bit on the frame and control arms
Old Oct 30, 2012 | 06:14 PM
EsByrd's Avatar
I'm running 4.5 with no issues on flat ground but I'm sure they would rub stuffed
