Help! Transfer Case - small crack (suggestions)
Old Mar 14, 2014 | 07:25 AM
Bobby G's Avatar
Default Help! Transfer Case - small crack (suggestions)
My buddy has a 99 Jeep - he was leaking oil, low and behold he took off his transfer case and he just told me that he has a small small pitted crack in it (less than a 1/4 inch) He describe it to me as pin hole size. (pic attached)
Is there anything he can do to temporarily fix this - he only has one car (the jeep) and doesn't really have the time or disposable income to just get work done this week. He is hoping there is a bandaid he can put on it for a few weeks. He knows that ultimately he needs to fix it correctly but he just can't right now…..thoughts are greatly appreciated.
Bobby
Old Mar 14, 2014 | 07:40 AM
Mark Doiron's Avatar
I repaired a casting defect (bubble) in my 1979 10th Anniversary Edition Trans Am engine block with Marine-Tex. He might give that a try. It is so hard that it can be drilled and tapped after curing. Buy it at local marine stores. He'd want the gray for best results.
Old Mar 14, 2014 | 09:35 AM
zedteamk2's Avatar
You might want to try JB Weld, the 2 part epoxy. It is liquid as opposed to a putty, so it may fill in any cracks a little better.
Just make sure everything is nice and clean before you apply
Old Mar 14, 2014 | 09:48 AM
Bobby G's Avatar
Thanks guys - think he went with the JB weld based on another recommendation from someone else too……Thanks for the FYI and info, much appreciated.
