Help with Vibration
2008 Unlimited Rubi, Auto, 513s, 35s TeraFlex 3".
Had Teraflex 3" installed (at a shop) and ended up with close to 5" of lift. Immediatley after lift experienced vibration. Replaced front DS with TeraFlex. Reduced vibration about 50%. Installed TeraFlex rear DS. Vibration worse than in the beginning. The vibration is one you can hear and feel. Have had lift re-torqued, tires renbalanced twice, drive shaft balance checked, etc. Vibratiions start at 45 and increase with speed. Have put 4K miles so lift should have settled by now. Shop's nexts step is to look at the gears. Any suggestions? Thanks.
agreed 100%. if the vibes got worse after installing your rear shaft, the pinion angle is probably off by a bit. you might want to give that a look as well.
an alignment will not effect driveline vibrations. too much caster, a pinion angle that is off OR a drive shaft that isn't perfectly balanced will. now that you are running 5.13's, your front ds will be spinning really really fast and any imperfection will translate into vibes. reducing the amount of caster you have will help. in the rear, you need to make sure that the ds and the pinion are parallel. if they are off, you will have vibes.
They removed the rear ds and drove it and there was no vibration so it has been isolated to a rear problem. They also said the pinon angle was correct. They also took the ds and had the balance checked and all was ok. Evidently somthing is still not right since it still has a vibration that you feel and hear. Appreciate the comments and help. Pretty frustrating experience.
