Help with Vibration
Old Feb 17, 2010 | 07:12 PM
jboss's Avatar
Default Help with Vibration
I need some help! My jeep has just recently started to vibrate when driving on the freeway. Not a shimmy or shacking just an all over vibration.
At first I thought my front drive shaft was finely going out, but I took it off and the vibration is still there. Next I thought maybe one of my tires was out of balanced?
Had all the tires rebalanced today but it did not help.
Here is some info: 08 4 door rubicon with 28k miles.
OME HD springs and LT shocks with AEV steering and rear track bar. Stock front and rear drive shafts. Lift has about 12k miles on it.
Tires are BFG ATs 315/70R17 on pro comp wheels.
Any help would be great.
Old Feb 17, 2010 | 07:14 PM
K9JKdriver's Avatar
Default vibration
Ball Joints
Old Feb 17, 2010 | 07:19 PM
jboss's Avatar
Originally Posted by K9JKdriver
Ball Joints
How do I check?
Old Feb 17, 2010 | 07:31 PM
mkjeep's Avatar
Check out this thread
https://www.jk-forum.com/forums/show...ht=ball+joints
Although yours does sound more like a balance problem, also do you rotate frequently?
Old Feb 17, 2010 | 08:01 PM
RedneckJeep's Avatar
Can you describe the vibration? Can you feel it more in the seats and floorboard or in the steering wheel? What frequency is the vibration? A high frequency vibration will almost be a buzzing like a heard of pissed off bumble bees. This will be very noticable. A low frequency vibration will be that of a tire out of balance.
Old Feb 17, 2010 | 08:43 PM
jboss's Avatar
The vibration is more in the seats and floorboard then the steering wheel.
It is a low frequency vibration that sound like it cycles on and off. I don't know if that makes sense?
Old Feb 18, 2010 | 04:13 AM
mkjeep's Avatar
My 37's did that, they were static bubble balanced no more vibs after getting the dynamic balanced.
