Help with Winch Running Backwards
Old Jun 23, 2009 | 06:52 AM
dougrobling's Avatar
Default Help with Winch Running Backwards
I have searched the JK-Forum and called Warn for support, but have not been able to find an answer to my issue.
I installed my new Warn M-8000 this weekend, and it runs the opposite direction of the button pushed. I have verified the wiring twice. (There are only 5 wires: Red-Positive, Black-Negative, and three short color coded wires for the motor leads)
Has anyone else seen this, and if so. what did you do to fix the problem?
Thanks
Old Jun 23, 2009 | 07:08 AM
JC JK's Avatar
Switch the Leads and see if it works.If it does there you go i would say it will
Old Jun 23, 2009 | 07:15 AM
ccwbrd's Avatar
If all wires check out, the solenoid is wired backwards or the plug for the controler is.
Old Jun 23, 2009 | 07:19 AM
JK Dawg's Avatar
Could the cable have been started in the wrong direction?
Old Jun 23, 2009 | 07:25 PM
pastorsteve's Avatar
Okay. It's working in both directions so that's good. Maybe the remote was wired backwards or labeled wrong. Either way, I'm sure warn will get you going in the right direction.
Old Jun 23, 2009 | 08:03 PM
Broz's Avatar
if the winch is working both ways just let all the line out and when it gets to the end just keep going till it pulls all the cable in and problem solved
Old Jun 24, 2009 | 03:51 AM
RedneckJeep's Avatar
Sounds like the cable was wound the wrong way. Does it come off the top or bottom of the drum?
Old Jun 24, 2009 | 04:00 AM
Warn got back with me, and suspects the controller.
A new one is on the way.
Old Jun 24, 2009 | 05:47 AM
Mark Doiron's Avatar
Originally Posted by dougrobling
Warn got back with me, and suspects the controller. A new one is on the way.
I was respooling my winchline just the other day and realized that I'd indavertently gotten it going the wrong direction on the spool. Just as others have pointed out: Wound it back out, got it going the correct direction and everything was hunky-dory after that. Why won't this fix yours, Doug?
