Here's the PLAN!!
Old Oct 10, 2008 | 06:08 PM
  #21
Breaktrack's Avatar
Originally Posted by tgrt
I have JE Reel shafts as well. They'll make them based on the size of the lift you have. You shouldn't have to measure.
Ah, gotcha. That is just what I needed to know.
Thanks,
Mac
Old Oct 10, 2008 | 06:09 PM
  #22
Breaktrack's Avatar
I've never known anyone to have good experiences with anything other than simple accessory add-on stuff. I'm sure there are some random good ones, but the impression I get is that mechanical skills can be learned on the job there. They'll never touch my Jeep.
Also good to know. I was unaware of that reputation.
Thanks,
Mac
Old Oct 10, 2008 | 06:12 PM
  #23
Breaktrack's Avatar
Originally Posted by jayrav
Change the front driveshaft. Go with any of the sponsers here that make driveshafts. If I were you I'd change the rear too, but thats me...I like to over build things Also go with the 5.13 gears for more power
Here is a list of future add ons:
1. Hypertech
2 Diff covers(ARB)
3. Chromoly axels front and rear
4. Crown brake lines
5. AEV hood
6. AEV snorkel
7. Woods relocations kits for muffler, SS and evap
8. last but not least...as a matter of fact this should be next...a set of adj control arms. This will improve your ride.
Alright, now I show my ignorance...lol. What is the Hypertech refer to?
I had already planned on the evap relocation, but forgot to list it in "The Plan", lol. The snorkel was a "wish list" item, the axels I wasn't sure about yet, so not in the plan, had not seen the AEV hood, just the snorkel, I'll have to look that up.
So what's up with relocating the muffler and SS? Have there been problems? The control arms were planned when I do the lift, whatever that winds up being..lol.
Thanks,
Mac
Old Oct 10, 2008 | 06:13 PM
  #24
Breaktrack's Avatar
Originally Posted by 08RUBIJK
You could try this out and let us know how it works...
2007 - 08 Jeep Wrangler JK and Rubicon 2 and 4 Door Models 5" Suspension System with SSV Shocks - Part # J4614SSV
Engineered by Jeep enthusiasts with sportsmen and rock crawlers in mind.
Trail Master coils and SSV shocks for a great ride on and off-road.
Standard quick disconnect sway bar links.
DOT approved braided steel, kevlar lined brake lines for front and rear included.
.156 Walled DOM tube replacement upper and lower control arm with flex joint for mavimum articulation.
Replacement front and rear track bars with heim joint ends for proper geometry and bind free movement.
An affordable package for the off-road enthusiast.
Fits 2 and 4 door JK, JK X and Rubicon models.
Easily accommodates 35" tall tires.
Kit includes detailed instructions and all necessary mounting hardware.
Easy to install: approximately 4 to 6 hours installation time.
OEM factory CV joints cannot withstand the new differential angles produced by lifting the vehicle thus wearing standard CV driveline prematurely. Therefore Trail Master Suspension strongly recommends upgrading to our front and rear double cardan drive lines for added durability and reliable off-road performance. Trail Master offers the convenience of purchasing suspension systems complete with drive lines or the option of purchasing the drive lines at a later date. Complete Kits: 2-Door Model PN J4615SSV / 4-Door Model PN J4616SSV Drive Lines: 2-Door Rear PN 951302 / 4-Door Rear PN 951304 / Front 2 & 4 Door Models PN 951303.
Uh, yeah..... you wouldn't just happen to know a ballpark figure on the cost of that list, would ya?? LOL.
Mac
Old Oct 10, 2008 | 06:15 PM
  #25
Breaktrack's Avatar
Originally Posted by rancid
sounds like a good plan.
Thanks, it's a start. I've had five Jeep vehicles in a row now, four Cherokees and two Wranglers, but it always seemed like anytime I decided to mod them up there was something else that had more priority, being a single dad for most of those years didn't help...lol.
Now, I'm in a position to get something done to this one, and I want to start soon, and take my time doing it right.
So, off we go!!!
Mac
Old Oct 10, 2008 | 06:20 PM
  #26
Breaktrack's Avatar
Originally Posted by hawgrider1200
I have not done any research on the prices of gears, there fore I am not qualified to make any statement about this issue but it seems to me if ya want 5:13 gears you would be spending the same as if you got 4:88 gears. Now if it was me and I was using this for a DD I would not go with the 4.88's or the 5:13's. I beleive 4:10's are sufficient for 35" tires. If you are just gonna play with your JEEP go with the 5:13's. As for your lift. I believe a body lift is superior over a suspension lift. A suspension lift moves the complete weight of your vehicle to a higher center of gravity. a body lift leaves your engine tranny and transfer case closer to the ground therefore your center of gravity while still being higher than stock is not as high as a suspension lift. Since stock JK's such as the Rubicon come from the factory with 32" tires I would guess that you only need 1.5 additional inches to clear 35" tires. One fellow on this forum was saying he ran 35" tires with no lift at all. He installed aftermarker fender flares that allowed him to clear the larger diameter tires. That is where your ground clearance is gonna come from, larger diameter tires. If you can get the clearance to run 35's without a lift your center of gravity would be lower. Still be higher than steck because of the larger diameter tires. Higher center of gravity equals to more easily rolling your JEEP. Think hard on that.
Yeah, there is the daily driver aspect to be considered. I do want to make it as capable as I can, while trying to not beat myself to death riding it on the street every day as well.
Do you think a compromise between the two might be the 4.10's? I'm not really all that worried about the center of gravity being too high with anything less than a 4" lift or more, I've driven a buddies setup that was lifted about 4" with a lift, and an additional 1" body lift, and it seemed really stable, but was higher than I wanted. I will probably just go with the 3" and leave it at that.
Thanks,
Mac
Old Oct 11, 2008 | 07:37 AM
  #27
Woods's Avatar
JeepSWAG
Sponsoring Manufacturer
Thanks,
Mac
If you ever plan to wheel over anything that would end up hitting your axle tubes, then moving the SS is a complete no-brainer. The stock location of the SS is just in front of and below the front right axle tube. One hit on a rock and it's gone. There's a bundle for the Evap can and SS relo kits on my site.
The muffler doesn't necessarily need to be moved, but it is in the way. When it gets hit, it doesn't just put dents in the bottom of it. I've seen the four heat shield bolts (located directly above) punch holes in the muffler. Other reasons to move the muffler is to improve the sound and performance. I designed my system with the 1BADJK testing in mind. The feedback that I get from buyers is better power at higher RPMs and better mileage. My kit requires that you relocate the Evap Can, but it looks like you plan to do this anyway.
Old Oct 11, 2008 | 01:08 PM
  #28
Breaktrack's Avatar
Good information, I shall give your site a perusal...lol.
Thanks,
Mac
Old Oct 11, 2008 | 04:26 PM
  #29
Breaktrack's Avatar
Originally Posted by N2rock
Yes, the evap relocation kit he makes is well worth the money and effort.
Now it would appear, that if I were to do the muffler relocate as well, then I could do the deep well storage compartment upgrade...lol.
More benefit, eh?
Mac
Old Oct 11, 2008 | 05:00 PM
  #30
44magjeeper's Avatar
i was just at the dealership today and was reading on the 09 wrangler, seems they have a 4 1/2 inch lift you can get as an option, you could check and see if if it would fit you 08 and warrenty info on it, just my useless
