Hey WOL
Your opinion, my rear is riding a little low when I load the back with tools, camping gear and such. I have a 4in Superlift. If I take the stock isolator out and replace it with my leftover REBB spacer which is 13/4in it will give me another 1 1/4 in the rear without the stock isolator in. Can't see payin for 1in spacers when I have these layin around. Any probs you see with this? I do have a JKS rear adj track bar but not adj control arms.
I can't blame you for that. I have this laying around, but I'm waiting on some different springs before I do the install. I didn't want to install them twice.
The air bags will work with after market springs. The pic shows them being used with Full Traction springs. Just need to make sure you get air bags that will fit within the spring.
unfortunately, every spring is a bit different and you will need to know what your interior diameter and height from the top of the spring perch to the base of the axle is. if your coil is not parallel, you will need to know what the interior diameter is both top and bottom. once you have all this info, air lift should be able to help you find something that will fit.
