High Altitude Blues
Old Jul 28, 2021 | 07:30 AM
bbolander's Avatar
Originally Posted by Dirtman Durden
And this helps me how?
It, along with other posts including mine, lets you know that you shouldn't be having a problem at high altitude because it isn't typical. So you can investigate further to see what the problem is.
Old Aug 3, 2021 | 11:46 AM
Dirtman Durden's Avatar
Well hell, I know I have a problem, because I have been at 13+ feet before without a problem. Otherwise I wouldn't be on here asking for help.
Old Aug 3, 2021 | 12:41 PM
resharp001's Avatar
Loved
Community Favorite
Originally Posted by Sixty4x4
The fuel can boil if the tank pressure drops. Check the fuel cap etc. What you describe is a classic for fuel starvation or boiling, Has nothing to do with engine temps.
You know what this makes me think of......I have a chamber vaccum packer, which I absolutely love btw, and when vac packing liquids there is a point at which even cold liquid will totally "boil" as the air is pulled out of the chamber and pressure falls (decreasing pressure creates lower boiling points). What you're saying here is the same thing I guess......the decreasing pressure causes the fuel to boil at a much lower temp than normal and the result is vapor lock in the fuel line. Your comment about unscrewing the gas cap would help raise the pressure in the tank, hence increase the boiling temp (back towards a more normal level) and keeping things happier in theory if I'm understanding. (sorry guys, I'm bit more dense when it comes to science). I've never thought about in terms of fuel delivery.
Sorry I can't add any value. It's an abnormal issue at hand and curious to see where this ends up.
Old Aug 26, 2021 | 05:29 PM
akguy09's Avatar
Have you checked fuel lines for cracks
Old Aug 31, 2021 | 02:14 PM
redridge's Avatar
try a free flow air filter. Maybe you can run with no air filter in the area where your jeep is shutting off for testing purpose.
Old Sep 1, 2021 | 06:47 AM
Sixty4x4's Avatar
5 Year Member
Loved
Community Favorite
Hey DD - did you make progress here? Or have you not been back to that altitude again since? Just to add another perhaps check - scrounge around enough to get the plug in fittings such as stock and tap into the fuel supply line to the rails and use an electrical transducer and gauge or cannot remember if the system monitors FP which would take a online scanner to tell the same.
