High Output Alernator
Old Mar 26, 2010 | 11:35 AM
ckmehl's Avatar
Default High Output Alernator
do anyone make a high output Alternator for the JK. i think the factory one is 160 amp. i'm looking for a 200 amp. i noticed when i have all of my light force lights on that it puts a heavy strain on the alt.
Old Mar 26, 2010 | 11:42 AM
ronjenx's Avatar
What is your indication that it is putting a heavy strain on your alternator?
Do you know how many amps it all draws?
Old Mar 26, 2010 | 12:00 PM
AZJeeper's Avatar
Community Favorite
What year is your JK? All 07 and 08 have 160 Amps, except for diesel which is 180 Amps. I believe that all gas engines through 2010 are 140 Amps. Don't know about the 2009/2010 diesels.
Old Mar 26, 2010 | 12:04 PM
ckmehl's Avatar
Default .....
2008 x 2dr. not power anything. my window sticker says 160amp if i remember right.
it has a higher wine noise when the lights are on. as well as the lights are dimming more when not on the gas, and the RPM's are lower. i cant find what the amp draw is on the Lightforce Stiker 170's are. but i have 6 of them.
Old Mar 26, 2010 | 12:31 PM
AZJeeper's Avatar
Community Favorite
Originally Posted by Riptide
6 55w lights is too much of a strain on the alt? I find that kinda odd
The Strikers are 100 Watts. That's still only about 50 amps for 6.
I would guess you have:
1. A bad battery
2. Poor electrical connections
3. A bad alternator
There should be more than enough "umph" in the battery to turn on the lights without the alternator. If you have a bad connection somewhere it might not be feeding the lamps with all of the power you think - check the ground. If the alternator isn't putting out anywhere near its rated output, you'll be straining your battery and the rest of your electrical system.
Old Mar 26, 2010 | 12:46 PM
qzing01's Avatar
Mean Green makes a H/O 200 amp. I think they even have a 240
Old Mar 26, 2010 | 01:31 PM
ckmehl's Avatar
Default ok
1. A bad battery
3. A bad alternator
i can turn all the lights on with out the jeep running and they all come on. when i have the jeep on and i turn the lights on at idle. i here the extra straine on the alt. when i give it gas the lights get brighter. when i let off the gas they dim. is this normal.
Old Mar 26, 2010 | 04:26 PM
nangulator's Avatar
How are thet wired up, were relays used?
Old Mar 26, 2010 | 04:36 PM
AZJeeper's Avatar
Community Favorite
Nope - not normal. If you have a functioning system, your alternator will be putting out about 14.4 volts - even at idle. It won't be pumping out 160 amps, but you shouldn't be seeing a big difference in brightness if the charging system is working correctly.
Try disconnecting a light at a time until the problem goes away. If you get to the last light at it is still showing the same problem, I KNOW you have an electrical issue - not an undersized alternator. I still put money on a bad ground.
I would assume you ran through a relay and aren't driving all 50 amps through a switch. Correct assumption?
Old Mar 26, 2010 | 04:59 PM
ckmehl's Avatar
Default Correct
[QUOTE=AZJeeper;1629134]Nope - not normal. If you have a functioning system, your alternator will be putting out about 14.4 volts - even at idle. It won't be pumping out 160 amps, but you shouldn't be seeing a big difference in brightness if the charging system is working correctly.
I would assume you ran through a relay and aren't driving all 50 amps through a switch. Correct assumption?[/QUOTE
correct. each set of lights is on a seperate switch and has there own relay. and each set is on there own 40 amp fuse.
