High steer kit
Old Mar 19, 2012 | 06:22 AM
Copperhead47's Avatar
Default High steer kit
How much of an improvement is the high steer kit on Rock Krawler lifts? Is it worth it to get the Max Travel System over the X factor lift? Or is the X factor by itself good, or comprable to stock, driving wise?
Old Mar 19, 2012 | 07:10 AM
wayoflife's Avatar
JK-Forum Founder
a high steer kit typically just gets your steering components like your tie rod, a little more up and out of the way. it shoudln't change the way your jeep drives and you would be fine with their normal kit. now, depending on how much lift you have, a drag link flip and track bar relocation bracket install will help improve your handling but, that is not the same thing.
Old Mar 19, 2012 | 07:52 AM
Well it says it has the relocation bracket, and adjustable trackbars. But i dont see the drag link flip kit listed. Where would i get one of those? Oh, and its a 3.5" lift.
Old Mar 19, 2012 | 08:27 AM
wayoflife's Avatar
JK-Forum Founder
well, if it comes with a track bar relocation bracket, it has to come with a drag link flip or dropped pitman arm and, correcting your steering geometry with something like this will help with your handling.
Old Mar 19, 2012 | 09:53 AM
Oh good. Well thanks for the info, i will get the X factor lift then. And the extra money i will be saving can go to some other mod. Probably some kind of winch mount bumper.
Old Mar 19, 2012 | 10:03 AM
wayoflife's Avatar
JK-Forum Founder
just to make sure we're on the same page, that relocation bracket that comes with your kit is for the FRONT axle and not the rear, correct? it's pretty common for a kit to come with a rear relocation bracket and an adjustable front track bar without a relocation bracket.
Old Mar 19, 2012 | 10:59 AM
Oh, no it says its for the rear. Along with front and rear adj track bars. So i would need to get one separatly?
Old Mar 19, 2012 | 11:09 AM
wayoflife's Avatar
JK-Forum Founder
front steering correction isn't "required" but, if you find that your handling is not quite as good as you would prefer, yes, you would need to get something separately to address it like a draglink flip/front track bar relocation system.
Old Mar 19, 2012 | 11:25 AM
Ok thanks. I will try it without first. Then if needed i will look into it
